Na nete je verzia 6/2011, hľadaj cez google.Vojta píše:nemá někdo aktuální epc kde už jsou díly na facelift corsy d?
Opel EPC 04 2008 - CZ
Re: Opel EPC 04 2008 - CZ
Tak Opel EPC 06/2011 sem rozjel, tak pokud někdo něco budete potřebovat z této verze, tak sem k dispozici
Zdravim, mam taky progblem z nicoho nic mi nejde spustit EPC, pouzival som ho bez problemov a jedneho dna mi napise toto ked to chcem spustit, vid screen .
a neviem ako to opravit, reinstall nepomaha, pretoze ked som to instaloval postupom kt. bol na stranke :
Installation:
1. We take the image, mount in any way, take out from it all.
1a. autorun.inf and setup.exe throw into the basket
2. Set GMGInfrastructure \ GMGInfrastructure.msi (Standartalone)
3. Set GMEApplication \ GMEApplication.msi
4. Set GMGLocalDB \ GMGLocalDB.msi
5. Set GMERomDB \ GMERomDB.msi
6. Open the Start menu and execute cmd.exe
and then in the DOS window, run 's TV turns three commands:
SET PATH = "C: \ Program Files \ Snap-on Business Solutions \ Global EPC \ GM \ jre1.6.0_02 \ bin";
cd "C: \ Program Files \ Snap-on Business Solutions \ Global EPC \ GM \ Configurator"
java-jar Configurator.jar
Before their execution must go to the root of drive C: by typing "cd \" without quotes of course, but with a space between cd and \
string takes the form C: \>
And then execute commands very carefully depending on what type or just copy from here. Hot keys in a DOS window Osovski not work, only the mouse.
7. Reboot your computer
8. Open IE and enter the address of the code:
http://127.0.0.1:351/PQMace/launcher.html or http://127.0.0.1:351/PQMace (all different)
... And enjoy a fully working version EPC4
Tak vsetko mi islo, a zrazu to zblblo :/
Dik za help
Kód: Vybrat vše
http://img99.imageshack.us/img99/5663/94846506.jpgInstallation:
Dik za help
v jakém browseru ho spouštíš?
Win XP SP3 , IE8
zkus smazat cookies
Ahoj hoši..stáhl jsem si EPC,nainstaloval,vše proběhlo v pořádku ale po najetí na internetovou adresu,a po zmáčknutí launch mi to píše :HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'epcGmeLicensor' defined in ServletContext resource [/WEB-INF/contexts/epc/gme/gme-common-lic.xml]: Cannot resolve reference to bean 'epcGmeLicensorUtils' while setting bean property 'licensorUtils'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'epcGmeLicensorUtils' defined in ServletContext resource [/WEB-INF/contexts/epc/gme/gme-common-lic.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is org.apache.tomcat.dbcp.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (
Java Client Version 3.0 Build Rel20070803(327 CanTa)
TB Java Server error <11035>: TransBase Multiplexer error report:
database <GME_ROM_1@Kubik-PC> does not exist
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:274)
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
atd,atd..nechtěl jsem to psát celý...
mám windows 7 64bit verzi,javu mám nejnovější,a už si nwm rady
pokud máte někdo nějaký zkušenosti,sem s nima budu moc rád. Díky Kulisek
message
exception
Kdyz sem to delal podle navodu:
tak mi to psalo uplne to same. S instalacni davkou od PepaSe probehne instalace v poradku i pod vistou a do program files kde byva problem se zapisem. Ale stale nefunguje. Myslim ze problem bude v te adrese. Kdyz dam show url opravdu vyjede http://server:port/dir ale to je podle me jenom navod jak zadat spravne tu adresu. Ale otazkou je jak ji teda zadat protoze navod http://NázevPC:351/PQMace ani http://localhost:351/PQMace nefunguje a na konci instalace se zadna adresa nezobrazi
ano, je to tak. Teď to nemám před očima, ale adresu si sestavíte sami a EPC bez problémů funguje... večer se podívám na tu adresu.wcrashw píše:...s instalacni davkou od PepaSe probehne instalace v poradku i pod vistou a do program files kde byva problem se zapisem. Ale stale nefunguje. Myslim ze problem bude v te adrese
Astra G Caravan Z16XE 2004
http://www.PepaS.cz - opravuji "nesvítící" displeje palubních počítačů MID a až přejdete na Astru-H či Zafiru-B, tak zase pro Vás něco budu mít
tak jsem se podíval: pod XP, s mojí instalační dávkou a s velmi čerstvým EPC se po spuštění Zobrazit URL vypíše:
XXX je název PC
ale přes http://XXX:351/PQMace se nespustí, spouštím přes http://localhost:351/PQMace a funguje 100%EPC – Adresa webového prohlížeče (URL) Uživatelé přistupují k EPC otevřením webového prohlížeče na této webové adrese http://XXX:351/PQMace
XXX je název PC
No tak to mi pod vistama nefunguje ani jedno. Nic nebudu to resit, pouziju kamarada Mike.S
Ale kazdopadne diky, ze jsi se podival a mel snahu mi pomoct
To se ceni
To se ceni
Ano, na XP to běží přesně, jak to PepaS popisuje
, velmi čerstvá zkušenost s přeinstalací. Jen se mi trochu hádaly prohlížeče
Mám Windows 7 Home Premium 64bit a už vzdávám EPC 2011. Na XP bez problému sem nainstaloval a spustil EPC 2009 bez žádnejch pitomejch .bat souborů a podobnejch nesmyslů.
Tady mám EPC 08/2011 Multi, je to ISO soubor, v Daemonu bez problému, akorát to nešlo nainstalovat přez setup.exe protože to hlísilo Wrong DVD, tak jsem nainstaloval všechny 4 části (GMGInfrastructure GMEApplication GMGLocalDB GMERomDB) ručně jak se psalo v návodech, Javu mám nainstalovanou, udělal sem i čachry s opel.bat souborem a do něho vložil ty 4 řádky a inteligentně (jelikož mám 64bit systém a věci se instalujou do Program Files (x86) ) sem přidal (x86) a změnil ty cesty na:
SET PATH="C:\Program Files (x86)\Snap-on Business Solutions\Global EPC\GM\jre1.6.0_02\bin";%PATH%
c:
cd "C:\Program Files (x86)\Snap-on Business Solutions\Global EPC\GM\Configurator"
java -jar Configurator.jar
spustil sem ten opel.bat, všechno proběhlo OK, samo se to vyplo, ja restartoval, v názvu PC a účtu nemám diakritiku a stejnak to nefachá. Když kliknu v prohlížeči na to Launch tak na me vyběhne ta vypíčená další stránka s tim HTTP 500 a tunou nesmyslů. A já už fakt nevim. Zlatý XP
c:
Nainstalovat Opel EPC do virtuálních XPéček a funguje vše jak má! Můj případ.
Opel Zafira CDX 1.8 16V - X18XE1 - LPG - Tempomat
Diagnostika: OP-COM v. 1.39 CZ
Re: IX. Opel Astra-G / Zafira sraz Praha 13.10. (update str.
HELE chlapci je to za dlouho tak KLÍDEK
, ne něco vymyslíme, ale musí to být když ne pro všechny tak alespoň pro většinu a nesmí to rozbourat rodinný rozpočty zůčastněných
PS : Jo a Honzo to EPC mi nechodí, furt to píše že to chce origo disk
