Cislo motora
dudus83
Cislo motora
Příspěvek od dudus83 »
mozte mi nejak zistit cislo motora podla vin-u? W0L000036V1177003. je to VeBe
Astra G, r. v. 1998, 1,6 16V, tmavomodra metla, nalietane zatial 195 tisic
Diagnostika OP-COM, KE-okolie, Tatranska Lomnica
Re: Cislo motora
Příspěvek od Mike.S »
jo, a nejenom číslo motoru:
W0L:General Motors
000036:4-DV. Sedan
V:1997
1:Rüsselsheim
177003:SERIAL NUMBER
motor: X16XEL
č. motoru: 20921921
vyrobena: 12.3.1997
první RZ: GL-FH 123
výbava:
2F3 = RÁDIO,CAR 400 2J5 = KOBEREC,VNITŘNÍ PODLAHA S/DELUX 65L = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 781 80I = VNITŘEK-ČERNÝ A01 = SKLO,TÓNOVANÝ A32 = ELEKTRICKY ŘÍZENÉ OKNA,PŘEDNÍ AG4 = PŘEDNÍ SEDADLO,LEVÉ,REGULÁTOR VÝŠKY,RUČNÝ AK5 = PRO BEZP.VAK ŘIDIČE A SPOLUJEZDCE AQ6 = PŘEDNÍ SEDADLO,NASTAVITELNÁ OPĚRKA AR6 = PÁS,ZADNÍ SEDADLO,STŘED,3 BODY AT0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,CELÁ AY3 = OPĚRKA HLAVY,PŘEDNÍ,TEXTIL,CELÁ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED BAH = IMOBILAJZER,ELEKTRICKÝ,VARIANT 2 C87 = ČTENÁŘSKA LAMPIČKA,ZADNÍ C90 = SVÍTILNA NA DVEŘÍCH CT3 = PRO NĚMECKO D09 = LOKETNÍ OPĚRKA,PŘEDNÍ,STŘED D64 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PASAŽÉR D74 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,STRANA ŘIDIČE DL8 = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ GT6 = POMĚR NÁPRAVY 4.19 K73 = ALTERNÁTOR,70AMP L91 = 16 BENZÍNOVÝ MOTOR M79 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ N40 = POSILOVAČ ŘÍZENÍ, BEZ PROMĚNNÉHO POMĚRU NA5 = EMISE,3 SMĚROVÝ KATALYTICKÝ KONVERTOR,VARIANT 2 NP5 = VOLANT,KŮŽE PB9 = KOLO,VOZOVKA,OCEL,18 OTVORŮ,51/2JX14 QCI = PNEUMATIKY,185/70 R 14-88H RUE = VYROBENÉ V RUESSELSHEIMU T6G = PANEL VYBAVENÍ,VNITŘNÍ,S/LUX,VARIANT 1 T96 = SVĚTLO DO MLHY PŘEDNÍ TN5 = BATERIE,44AH U07 = HOUKAČKA,TROUBA U16 = PŘÍSTROJ,TACHOMETR U83 = REPRODUKTOR,6 W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W2V = PÍSMO,EQUIP,VARIANT, VYNECHEJTE W3X = MOTOR,SZENTGOTTHARD W4J = CD W4Y W6G = VYBAVENÍ,TEXTIL,S/LUX,VARIANT 1 W8X = DODATEČNÉ ČÁSTI, RÁDIO INSTALACE XA3 = OPEL XG3 = PRO NĚMECKO Z0F = PRO NĚMECKO Z1C = KUPOLOVÉ SVÍTIDLO Z1Y = BARVA,DVA POVLAKY Z3G = PÍSMO,CD
Marko
Re: Cislo motora
Příspěvek od Marko »
Hmm, pěkně. Mike.S, carrpass bys uměl zjistit?
OpCom 2010 USB EN
Re: Cislo motora
Příspěvek od Defender »
JOJO no Mike ten umí s tímhle zázraky :lol: , taky mám takový výpis uložený :) 8)
Marko
Re: Cislo motora
Mike.S, můžeme se nějak domluvit?
OpCom 2010 USB EN
Re: Cislo motora
car pass neumím :( , to budeš muset do Opelu
Marko
Re: Cislo motora
tak to je škoda... :cry:
OpCom 2010 USB EN
Re: Cislo motora
nebreč, za 700,- +/- ho máš 8) já si ho tam taky musel nechat vystavit
Marko
Re: Cislo motora
no, já úplně krvácím, když vidím tu cenu :? :( :cry:
OpCom 2010 USB EN
dudus83
Re: Cislo motora
fuuu, to je sila. som maximalne prekvapeny. dakujem. a teraz mi poradte, ako vybrat vodnu pumpu. bud je to toto: http://test.autokelly.sk/detail.aspx?Pr ... GR%20PA541
alebo toto: http://test.autokelly.sk/detail.aspx?Pr ... R%20PA541A
je to rozdelene samozrejme od cisla motora, a tam je v tom cisle aj nedno ci dve pismena a VeBe nema. :?
Re: Cislo motora
ty odkazy nic neukazují :o
edit?: číslo dílu Opel je 13 34 066 a je to díl použitelný v rozsahu 02LD5821-02MZ5253 a do -20U75998, snad Ti pomůže tohle
dudus83
Re: Cislo motora
Re: Cislo motora
tak je to tahle http://www.elitecat.sk/ArticleDetail.as ... eId=100091 když se podíváš na ty OE čísla, tak je tam hned na druhém řádku napsáno Opel 1334066 a to je to číslo, co jsem Ti dával o 2 příspěvky výš 8)
dudus83
Re: Cislo motora
velka vdaka. 8)
Re: Cislo motora
Příspěvek od mirda2908 »
nasel sem to pri servisni knizce co to znamena???diky
