Counter Strike 1.6 - CS ToFu 217.11.249.78:27692
Capone
Re: Counter Strike 1.6 - 93.184.69.132:27057 PB Fy Maps
Příspěvek od Capone »
ale ostaní jsou pak v prdelce :D
Tak dneska čisté náhodně začíná pařba od 19:30 ??? ( IP pak dopíšu ) :wink:
... jinak Astra H Caravan...
Příspěvek od Mike.S »
jak si nabinduju nákup na jedno tlačítko?
zEjn
Příspěvek od zEjn »
// Nakup
bind "y" "buy"
bind "i" "buyammo1"
bind "u" "buyammo2"
bind "o" "buyequip"
bind "F7" "deagle; secammo"
bind "F2" "sgren"
bind "F3" "hegren"
bind "F4" "flash;flash"
bind "F5" "m4a1;ak47; primammo"
bind "F6" "mp5 ;buyammo1;buyammo1"
bind "F10" "awp;buyammo1;"
bind "F9" "defuser"
bind "F12" "vest"
bind "ENTER" "vesthelm"
bind "INS" "usp;buyammo2;buyammo2;buyammo2"
bind "F11" "famas;primammo"
takhle to mam ja, klavesy si muzes prehazet jak chces
jinak si vytvor soubor autoexec.cfg a doneho to uloz a pak nakopiruj do "C:\Games\CS\cstrike" ( nebo kde to mas nainstalovany )
az spustis hru (pripojis na server) tak napis do konzoly "exec autoexec.cfg" teoreticky by se to melo nacist samo, ale radsi...
brhy
Příspěvek od brhy »
unbindall
bind "TAB" "+showscores"
bind "ESCAPE" "cancelselect"
bind "SPACE" "drop"
bind "'" "+moveup"
bind "+" "sizeup"
bind "-" "sizedown"
bind "/" "+movedown"
bind "0" "slot10"
bind "1" "slot1"
bind "2" "slot2"
bind "3" "slot3"
bind "4" "slot4"
bind "5" "slot5"
bind "6" "slot6"
bind "7" "slot7"
bind "8" "slot8"
bind "9" "slot9"
bind ";" "+mlook"
bind "=" "podbotmenu"
bind "[" "invprev"
bind "]" "invnext"
bind "`" "toggleconsole"
bind "a" "+moveleft"
bind "m" "buyammo2"
bind "d" "+moveright"
bind "f" "+attack2"
bind "MOUSE2" "+jump"
bind "j" "buyequip"
bind "b" "buy"
bind "n" "buyammo1"
bind "MOUSE5" "+reload"
bind "s" "+back"
bind "t" "stopsound"
bind "ENTER" "+use"
bind "w" "+forward"
bind "~" "toggleconsole"
bind "UPARROW" "+forward"
bind "DOWNARROW" "+back"
bind "LEFTARROW" "+left"
bind "RIGHTARROW" "+right"
bind "ALT" "+strafe"
bind "SHIFT" "+duck"
bind "CTRL" "+speed"
bind "F5" "snapshot"
bind "F6" "save quick"
bind "F7" "load quick"
bind "F8" "adjust_crosshair"
bind "F10" "quit prompt"
bind "F12" "chooseteam"
bind "INS" "+klook"
bind "DEL" "messagemode"
bind "PGDN" "+lookdown"
bind "PGUP" "+lookup"
bind "END" "messagemode2"
bind "MWHEELDOWN" "invnext"
bind "MWHEELUP" "invprev"
bind "MOUSE1" "+attack"
bind "PAUSE" "pause"
voice_scale "2.000000"
voice_enable "1"
voice_forcemicrecord "1.000000"
console "1.0"
fps_max "101"
fps_modem "0"
crosshair "1.000000"
gamma "3.000000"
brightness "1.000000"
con_color "255 155 50"
net_graph "3"
net_scale "5"
net_graphpos "1"
sv_voiceenable "1"
sv_aim "0"
hpk_maxsize "0"
viewsize "120.000000"
ati_subdiv "2"
ati_npatch "1.0"
r_bmodelhighfrac "5"
mp_decals "300"
gl_dither "1"
gl_polyoffset "0.1"
gl_overbright "0"
gl_flipmatrix "0"
gl_monolights "0"
s_rolloff "1"
s_doppler "0"
s_distance "60"
s_automin_distance "2"
s_automax_distance "30"
s_min_distance "5"
s_max_distance "1000"
s_leafnum "0"
s_refgain "0.4"
s_refdelay "4"
s_polykeep "1000000000"
s_polysize "10000000"
s_numpolys "200"
s_bloat "2"
s_verbwet "0.25"
s_a3d "0.000000"
s_eax "0.000000"
volume "0.990000"
suitvolume "0.250000"
hisound "1.000000"
bgmvolume "1.000000"
MP3Volume "0.800000"
_snd_mixahead "0.1"
name "teh_h"
team ""
model ""
skin ""
topcolor "0"
bottomcolor "0"
rate "25000.000000"
cl_updaterate "100"
cl_lw "1"
cl_lc "1"
cl_dlmax "128"
cl_himodels "0.000000"
cl_idealpitchscale "0.8"
cl_timeout "35"
cl_cmdbackup "2"
cl_download_ingame "1"
cl_allowdownload "1"
cl_allowupload "1"
cl_cmdrate "100"
lookstrafe "0.000000"
lookspring "0.000000"
cl_forwardspeed "400"
cl_backspeed "400"
cl_vsmoothing "0.05"
m_pitch "0.022"
m_yaw "0.022"
m_forward "1"
m_side "0.8"
m_filter "0.000000"
sensitivity "1.200000"
joystick "0.000000"
hud_takesshots "0"
fastsprites "0"
cl_corpsestay "180"
_cl_autowepswitch "1"
hud_capturemouse "1"
hud_draw "1"
cl_righthand "1"
cl_minmodels "1"
cl_dynamiccrosshair "0"
hud_fastswitch "1"
hud_centerid "1"
voice_modenable "1"
hud_classautokill "1"
setinfo "_vgui_menus" "0"
setinfo "_ah" "0"
+mlook
+jlook
HEATON-cfg setup cs1,6 :D su tam nastavenia aj na grafiku :D
skopirujsi to do notepadu poupravuj ako potrebujes ale ulozit to musis pod nieco.cfg len nie autoexec lebo potom ti to nespusti cez konzolu a potom v cs napis do console autoexec b.cfg napr a nacita ti to komplet nastavenia
zEjn
Příspěvek od zEjn »
brhy: ale on chtel nakupovaci skripty ne config .. navic to, ze je to heatonuv config v kterym je plno sracek je mu jako normalnimu smrtelnikovi k ho... :lol:
brhy
Příspěvek od brhy »
tak na hovno mu to byt moze ale ked si to cele nakriptuje podla seba tak je to neskutocne uzitocna vec
brhy
Příspěvek od brhy »
super isiel som dat zakalene zraky a ze som Banned nechapem ako ma moze zabanovat ked som tam nikdy nehral ?
brhy
Příspěvek od brhy »
sak ja im dam kretenom ked zistim kto to boltak mu natrhnem usmev :D pockaj idem neako zistit ip :D ak viete kde budem vdacny :D
zEjn+brhy: díky za bind 8)
ale já jsem si myslel, že si pod jednou klávesou nakoupím AK47/M4A1+vestu+helmu+flash+granát, to asi nejde co? tady tomu "programovacímu" jazyku CS++ :mrgreen: moc nerozumím, teda vůůůbec :( :roll:
edit: brhy, Tvoje IP je 81.89.56.250 :wink: :|
zEjn
Příspěvek od zEjn »
zEjn
Příspěvek od zEjn »
mike: bind "F5" "m4a1;ak47; primammo; vesthelm; flash;flash; hegren"
klavesu si muzes zmenit ;)
no vidiš, že to jde :mrgreen: díky 8) 8) 8) 8) 8) 8)
edit: kam chodíte na ty syntaxe příkazů??
Capone
Tak co pardi,jak to dneska bude ??? :)
Příspěvek od lukaskpd »
mohly by sme dat
1.7TD ( 17DTL ) + CHIP
www.jkcolor.iplace.cz/
synologic
Příspěvek od synologic »
Čekáme na IP. :?: 8)
Caravan
